Ga door naar hoofdinhoud
Blackberry Curve 9300 Speaker Replacement
Wat je nodig hebt
  1. Blackberry Curve 9300 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Speaker Replacement: stap 3, afbeelding 1 van 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Speaker Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Speaker Replacement: stap 5, afbeelding 1 van 2 Blackberry Curve 9300 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Speaker Replacement, Speaker: stap 10, afbeelding 1 van 1
    • Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
  11. Blackberry Curve 9300 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Carefully pull keyboard base up and away from phone.
    • Disconnect keyboard base from phone completely.
  12. Blackberry Curve 9300 Speaker Replacement: stap 12, afbeelding 1 van 3 Blackberry Curve 9300 Speaker Replacement: stap 12, afbeelding 2 van 3 Blackberry Curve 9300 Speaker Replacement: stap 12, afbeelding 3 van 3
    • Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Speaker Replacement: stap 13, afbeelding 1 van 2 Blackberry Curve 9300 Speaker Replacement: stap 13, afbeelding 2 van 2
    • Using a prying tool, find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • Prying tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Speaker Replacement: stap 14, afbeelding 1 van 2 Blackberry Curve 9300 Speaker Replacement: stap 14, afbeelding 2 van 2
    • From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Speaker Replacement: stap 15, afbeelding 1 van 1
    • Insert tweezers into the small holes on the top of the speaker.
  16. Blackberry Curve 9300 Speaker Replacement: stap 16, afbeelding 1 van 2 Blackberry Curve 9300 Speaker Replacement: stap 16, afbeelding 2 van 2
    • Lift the speaker up to remove the speaker from phone.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Alek Squires
431 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-7, Forte Fall 2013 Lid van Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 4,143
