Ga door naar hoofdinhoud
Blackberry Curve 8330 Battery Replacement
  1. Blackberry Curve 8330 Battery Replacement, Remove Back Cover: stap 1, afbeelding 1 van 1
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 Battery Replacement, Remove Battery: stap 2, afbeelding 1 van 1
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Riley McGovern
22 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-11, Forte Spring 2012 Lid van Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 2,236
