Inleiding
This guide will show you how to:
- Remove the battery
- Remove the front panel
- Replace the speaker
Wat je nodig hebt
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
Één andere persoon heeft deze handleiding voltooid.
