Ga door naar hoofdinhoud
Blackberry Curve 8320 Speaker Replacement
Wat je nodig hebt
  1. Blackberry Curve 8320 Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Blackberry Curve 8320 Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Speaker Replacement, Front Panel: stap 3, afbeelding 1 van 3 Blackberry Curve 8320 Speaker Replacement, Front Panel: stap 3, afbeelding 2 van 3 Blackberry Curve 8320 Speaker Replacement, Front Panel: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Speaker Replacement: stap 4, afbeelding 1 van 2 Blackberry Curve 8320 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Speaker Replacement: stap 5, afbeelding 1 van 2 Blackberry Curve 8320 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 Speaker Replacement, Speaker: stap 8, afbeelding 1 van 3 Blackberry Curve 8320 Speaker Replacement, Speaker: stap 8, afbeelding 2 van 3 Blackberry Curve 8320 Speaker Replacement, Speaker: stap 8, afbeelding 3 van 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 Speaker Replacement: stap 9, afbeelding 1 van 2 Blackberry Curve 8320 Speaker Replacement: stap 9, afbeelding 2 van 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 Speaker Replacement: stap 10, afbeelding 1 van 3 Blackberry Curve 8320 Speaker Replacement: stap 10, afbeelding 2 van 3 Blackberry Curve 8320 Speaker Replacement: stap 10, afbeelding 3 van 3
    • Remove the back case.
    • The speaker is located on the back case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Aiello
89 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-6, Regan Fall 2011 Lid van Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 17
Altijd: 2,209
