Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Pull up on the top edge of the battery to remove it.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Remove the two top screws with a T5 Torx screwdriver.
Gently pry off the side casings from the top.
You will not need to remove the sides on the bottom.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
Één andere persoon heeft deze handleiding voltooid.
