Ga door naar hoofdinhoud
Blackberry Curve 8320 Front Panel Replacement
Wat je nodig hebt
  1. Blackberry Curve 8320 Front Panel Replacement, Battery: stap 1, afbeelding 1 van 2 Blackberry Curve 8320 Front Panel Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Front Panel Replacement, Front Panel: stap 3, afbeelding 1 van 3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: stap 3, afbeelding 2 van 3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Front Panel Replacement: stap 4, afbeelding 1 van 2 Blackberry Curve 8320 Front Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Front Panel Replacement: stap 5, afbeelding 1 van 2 Blackberry Curve 8320 Front Panel Replacement: stap 5, afbeelding 2 van 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Front Panel Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Front Panel Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Aiello
89 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-6, Regan Fall 2011 Lid van Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,712
