Ga door naar hoofdinhoud
Blackberry Bold 9900 Back Case Replacement
Wat je nodig hebt
  1. Blackberry Bold 9900 Back Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Back Case Replacement: stap 2, afbeelding 1 van 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: stap 3, afbeelding 1 van 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Back Case Replacement, MicroSD card: stap 4, afbeelding 1 van 2 Blackberry Bold 9900 Back Case Replacement, MicroSD card: stap 4, afbeelding 2 van 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Back Case Replacement, Keyboard: stap 5, afbeelding 1 van 2 Blackberry Bold 9900 Back Case Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Back Case Replacement: stap 6, afbeelding 1 van 2 Blackberry Bold 9900 Back Case Replacement: stap 6, afbeelding 2 van 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Back Case Replacement: stap 7, afbeelding 1 van 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Back Case Replacement: stap 8, afbeelding 1 van 2 Blackberry Bold 9900 Back Case Replacement: stap 8, afbeelding 2 van 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Back Case Replacement, Back Case: stap 9, afbeelding 1 van 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Back Case Replacement: stap 10, afbeelding 1 van 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sowmika
253 Reputatie
2 handleidingen geschreven
Baylor, Team S1-G4, Johnson Spring 2018 Lid van Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 1,455
