Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Using your fingernails, lift the sides of the battery.
Remove the battery.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Orient the device so that the screen is facing you.
Using a spudger, remove the ear piece cover.
Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
Remove the back chassis by gently pulling the chassis back and forth.
Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
Using a pair of tweezers, lift and remove the following:
The two round connectors on the top of the mother board.
The flat connector in the lower corner of the mother board.
Using your fingers, carefully lift and remove the mother board.
Using a pair of tweezers, remove the three ribbon connectors.
Remove the mother board by lifting the board upward.
Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
Remove the faceplate by lifting the plate upward.
Using a plastic pry tool, lift and remove the three tabs securing the trackpad restrainer to the trackpad.
Flip the device over. The screen is facing upwards.
Remove the trackpad restrainer.
Slowly remove the trackpad by gently pulling the trackpad away from the device.
