Ga door naar hoofdinhoud
Blackberry Bold 9650 Keypad Replacement
Wat je nodig hebt
  1. Blackberry Bold 9650 Keypad Replacement, Battery: stap 1, afbeelding 1 van 2 Blackberry Bold 9650 Keypad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Keypad Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Keypad Replacement, Back Chassis: stap 5, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Keypad Replacement: stap 8, afbeelding 1 van 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Keypad Replacement, Mother Board: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Keypad Replacement: stap 10, afbeelding 1 van 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Keypad Replacement: stap 11, afbeelding 1 van 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Keypad Replacement: stap 12, afbeelding 1 van 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Keypad Replacement, Faceplate: stap 13, afbeelding 1 van 2 Blackberry Bold 9650 Keypad Replacement, Faceplate: stap 13, afbeelding 2 van 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  14. Blackberry Bold 9650 Keypad Replacement, Keypad: stap 14, afbeelding 1 van 1
    • Lift the keypad out of the the front cover.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ryan
696 Reputatie
11 handleidingen geschreven
Clemson, Team 2-5, Benson Spring 2012 Lid van Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 88
Altijd: 7,609
