Ga door naar hoofdinhoud
Blackberry Bold 9650 Back Chassis Replacement
Wat je nodig hebt
  1. Blackberry Bold 9650 Back Chassis Replacement, Battery: stap 1, afbeelding 1 van 2 Blackberry Bold 9650 Back Chassis Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Back Chassis Replacement: stap 2, afbeelding 1 van 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Back Chassis Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Back Chassis Replacement: stap 4, afbeelding 1 van 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Back Chassis Replacement, Back Chassis: stap 5, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Back Chassis Replacement: stap 6, afbeelding 1 van 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Back Chassis Replacement: stap 7, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Back Chassis Replacement: stap 8, afbeelding 1 van 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Ryan
696 Reputatie
11 handleidingen geschreven
Clemson, Team 2-5, Benson Spring 2012 Lid van Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 3,166
