Ga door naar hoofdinhoud
Blackberry Bold 9000 Trackball Replacement
Wat je nodig hebt
  1. Blackberry Bold 9000 Trackball Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: stap 2, afbeelding 1 van 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: stap 3, afbeelding 1 van 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: stap 7, afbeelding 1 van 1
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: stap 8, afbeelding 1 van 1
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: stap 9, afbeelding 1 van 1
    • Lift the trackball out of its socket.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kelly
566 Reputatie
6 handleidingen geschreven
Cal Poly, Team 8-17, Maness Winter 2012 Lid van Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 11,169
