Onderdelen
Geen onderdelen nodig.
  1. Place your Blackberry facedown in front of you.
    • Place your Blackberry facedown in front of you.
  2. Press the cover release button on the bottom of your device. Lift and remove the back cover.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. From the top, use your fingernail to lift the battery out.
    • From the top, use your fingernail to lift the battery out.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Remove the SIM card.
    • Remove the SIM card.
  6. Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  7. Use the plastic opening tool to remove the rear case.
    • Use the plastic opening tool to remove the rear case.
  8. The two antennas are built into the rear case. Replace this piece to replace the antenna.
    • The two antennas are built into the rear case. Replace this piece to replace the antenna.
Conclusie
Jacob
125 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-17, Maness Winter 2012 Lid van Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 5
Altijd: 4,892
