Ga door naar hoofdinhoud
Blackberry 8700c Battery Replacement
  1. Blackberry 8700c Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Blackberry 8700c Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Blackberry 8700c Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
  2. Blackberry 8700c Battery Replacement: stap 2, afbeelding 1 van 2 Blackberry 8700c Battery Replacement: stap 2, afbeelding 2 van 2
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
    • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
    • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
Conclusie
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
42 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-4, Maness Fall 2009 Lid van Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 2,791
