Ga door naar hoofdinhoud
Blackberry 7520 Motherboard Replacement
Wat je nodig hebt
  1. Blackberry 7520 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Motherboard Replacement: stap 2, afbeelding 1 van 3 Blackberry 7520 Motherboard Replacement: stap 2, afbeelding 2 van 3 Blackberry 7520 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 Motherboard Replacement: stap 4, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Motherboard Replacement: stap 6, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 Motherboard Replacement: stap 7, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 Motherboard Replacement: stap 8, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 Motherboard Replacement: stap 9, afbeelding 1 van 2 Blackberry 7520 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
Conclusie
Nathan
31 Reputatie
6 handleidingen geschreven
Cal Poly, Team 5-7, Forte Winter 2010 Lid van Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,566
