Inleiding
Disassembling the logic board in the rear of the Blackberry allows you to get to the LCD screen and keypad.
Onderdelen
Geen onderdelen nodig.
  1. Turn the phone upside down.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
    Voeg opmerking toe
  2. Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
    Voeg opmerking toe
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
    Voeg opmerking toe
    • Use a pick or small tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
    Voeg opmerking toe
  3. Verspreid de kerstsfeer
    Krijg 12€ korting op je aankoop van 50€ of meer met de code FIXMAS12
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
    Voeg opmerking toe
    • Slide the rear panel forward to reveal the logic board.
    Voeg opmerking toe
    • Remove the indicated screws using a T6 Torx screwdriver.
    Voeg opmerking toe
    • Remove the logic board.
    • Remove the indicated screw using the T6 Torx screwdriver.
    Voeg opmerking toe
    • Pull the metal plate away from the front panel of the cell phone.
    Voeg opmerking toe
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
    Voeg opmerking toe
Conclusie
Nathan
31 Reputatie
6 handleidingen geschreven
Cal Poly, Team 5-7, Forte Winter 2010 Lid van Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 3,459
