Inleiding
For removing and replacing the Blackberry 7520 battery, follow this guide.
Gereedschap
Geen gereedschap nodig.
Onderdelen
Geen onderdelen nodig.
Turn the phone upside down.
Push down on the black button on the back of the phone to slide the rear panel off.
The battery should be visible now.
Hold the BlackBerry in one hand face-up with the screen facing towards you.
To install the battery turn the phone on its back.
Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
Once the battery is lined up push the battery in and down until it is locked in.
Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
Push the panel inwards then down until it locks in.
Once the panel is in you have successfully changed your battery!
