Ga door naar hoofdinhoud
Blackberry 7105t Speaker Replacement
Wat je nodig hebt
  1. Blackberry 7105t Speaker Replacement, Blackberry 7105t Disassembly: stap 1, afbeelding 1 van 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Speaker Replacement: stap 5, afbeelding 1 van 3 Blackberry 7105t Speaker Replacement: stap 5, afbeelding 2 van 3 Blackberry 7105t Speaker Replacement: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Speaker Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Speaker Replacement: stap 7, afbeelding 1 van 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Speaker Replacement, Speaker: stap 8, afbeelding 1 van 2 Blackberry 7105t Speaker Replacement, Speaker: stap 8, afbeelding 2 van 2
    • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
    • Place the three clips in plastic bag and set aside.
    • Once clips are removed, you will have full access to remove the speaker.
Conclusie
CeeJay
19 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-17, Regan Fall 2009 Lid van Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,180
