Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide is a single step that is a prerequisite for the screen and keyboard guides.
Onderdelen
Geen onderdelen opgegeven.
  1. With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Remove the battery by pushing against it from the right and then pulling towards you.
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  6. Use a plastic opening tool or your fingernails to remove the plastic backing. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  7. Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  8. The black battery casing and logic board can now be separated for the following steps.
    • The black battery casing and logic board can now be separated for the following steps.
  9. The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
Conclusie
CeeJay
19 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-17, Regan Fall 2009 Lid van Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,243
