Ga door naar hoofdinhoud
BlackBerry World Edition 8830 Trackball Replacement
Wat je nodig hebt
  1. BlackBerry World Edition 8830 Trackball Replacement, Trackball: stap 1, afbeelding 1 van 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: stap 1, afbeelding 2 van 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: stap 1, afbeelding 3 van 3
    • Make sure the phone is powered off before removing the trackball.
    • Gently use the Small Flathead Screwdriver or plastic opening tool to go under the chrome ring surrounding the trackball.
    • Pry the chrome ring upwards with the tool until it begins to lift up.
    • Once it begins to lift up, gently remove the chrome ring from around the trackball.
    • When re-assembling the phone, be sure to orient the chrome ring so that the missing tab is at the top.
  2. BlackBerry World Edition 8830 Trackball Replacement: stap 2, afbeelding 1 van 2 BlackBerry World Edition 8830 Trackball Replacement: stap 2, afbeelding 2 van 2
    • After removing the chrome ring, slowly lift up the remaining piece with tweezers.
    • Slowly remove the small plastic bottom using the Plastic Opener tool. Be careful not to bend the metal frame when removing the bottom plastic piece.
    • Using your hands, remove the white plastic piece, revealing the small metal frame, the scroll wheels, and the trackball.
  3. BlackBerry World Edition 8830 Trackball Replacement: stap 3, afbeelding 1 van 1
    • Slowly remove the trackball, being cautious not to scratch the ball or the scroll wheels.
    • Using a soft cloth, carefully remove any dust around the scroll wheels or the trackball itself.
    • While the trackball is removed, you may clean the sensor in the hole where the trackball is usually located.
Conclusie
tbace
28 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-27, Amido Spring 2012 Lid van Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 1,006
