Ga door naar hoofdinhoud
BlackBerry Tour 9630 Trackball Replacement
Wat je nodig hebt
  1. BlackBerry Tour 9630 Trackball Replacement, Battery: stap 1, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement, Battery: stap 1, afbeelding 2 van 2
    • Position the phone so that the keyboard is facing down and the back is facing up.
  2. BlackBerry Tour 9630 Trackball Replacement: stap 2, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement: stap 2, afbeelding 2 van 2
    • Push the center silver button upwards to release the back cover.
    • Take the back cover off and set it to the side.
  3. BlackBerry Tour 9630 Trackball Replacement: stap 3, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement: stap 3, afbeelding 2 van 2
    • Grip the battery where the light grey half circles are located and pull up.
    • Set the removed battery to the side with the back cover.
  4. BlackBerry Tour 9630 Trackball Replacement, Keypad: stap 4, afbeelding 1 van 1
    • If there is an SD card, press gently on the card and slide up to remove.
    • If there is a SIM card, press gently on the card and slide left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
  5. BlackBerry Tour 9630 Trackball Replacement: stap 5, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement: stap 5, afbeelding 2 van 2
    • Using an opening tool, pry the top plastic covering off. As shown in the second picture.
    • There is glue holding the top plastic covering. Additional pressure may be needed.
  6. BlackBerry Tour 9630 Trackball Replacement: stap 6, afbeelding 1 van 1
    • Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
  7. BlackBerry Tour 9630 Trackball Replacement: stap 7, afbeelding 1 van 1
    • Remove the back casing.
    • This may take some wiggling to fully remove the part.
  8. BlackBerry Tour 9630 Trackball Replacement: stap 8, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement: stap 8, afbeelding 2 van 2
    • Using a small opening tool, pry up the pop ribbon cable from the motherboard.
  9. BlackBerry Tour 9630 Trackball Replacement: stap 9, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement: stap 9, afbeelding 2 van 2
    • Using a small opening tool, remove the side antenna cable.
  10. BlackBerry Tour 9630 Trackball Replacement: stap 10, afbeelding 1 van 1
    • Gently push up on the keyboard from below to snap the front cover off.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 Trackball Replacement: stap 11, afbeelding 1 van 1
    • Remove the keypad.
  12. BlackBerry Tour 9630 Trackball Replacement, Trackball: stap 12, afbeelding 1 van 2 BlackBerry Tour 9630 Trackball Replacement, Trackball: stap 12, afbeelding 2 van 2
    • Remove the trackball.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mia
524 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 782
