Ga door naar hoofdinhoud
BlackBerry Tour 9630 LCD Screen Replacement
Wat je nodig hebt
  1. BlackBerry Tour 9630 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip phone over so the back side is facing up.
  2. BlackBerry Tour 9630 LCD Screen Replacement: stap 2, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Push up on the center silver button to release the back cover.
    • Remove the back cover.
  3. BlackBerry Tour 9630 LCD Screen Replacement: stap 3, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Grip the battery where the light grey half circles are located and pull up on the battery.
    • Remove the battery.
  4. BlackBerry Tour 9630 LCD Screen Replacement, Keypad: stap 4, afbeelding 1 van 1
    • If there is an SD card, press gently on the card and slide up to remove.
    • If there is a SIM card, press gently on the card and slide left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
  5. BlackBerry Tour 9630 LCD Screen Replacement: stap 5, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Using the large blue plastic opening tool, pry the top plastic covering off.
    • There is glue holding the top plastic covering. Additional pressure may be needed.
  6. BlackBerry Tour 9630 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
  7. BlackBerry Tour 9630 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the back casing by wiggling it open.
  8. BlackBerry Tour 9630 LCD Screen Replacement: stap 8, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Using the small plastic opening tool, pry up the pop ribbon cable from the motherboard.
  9. BlackBerry Tour 9630 LCD Screen Replacement: stap 9, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Using the small plastic opening tool, remove the side antenna cable.
  10. BlackBerry Tour 9630 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Gently push up on the keyboard and snap the front cover off.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove the keypad.
  12. BlackBerry Tour 9630 LCD Screen Replacement, LCD Screen: stap 12, afbeelding 1 van 2 BlackBerry Tour 9630 LCD Screen Replacement, LCD Screen: stap 12, afbeelding 2 van 2
    • Gently lift the motherboard to expose several ribbon cables.
    • Use the small plastic opening tool to disconnect the orange LCD ribbon from the square end of the ribbon cables.
  13. BlackBerry Tour 9630 LCD Screen Replacement: stap 13, afbeelding 1 van 1
    • Flip the phone over. Using the large plastic opening tool, pry the LCD screen from the motherboard.
    • Replace the LCD screen
    • The LCD screen is held in place with glue.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Mia
524 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 873
