Ga door naar hoofdinhoud
BlackBerry Torch 9850 Battery Replacement
  1. BlackBerry Torch 9850 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the device.
    • Press and hold down the power/end button on the phone until phone powers off and the screen goes black.
  2. BlackBerry Torch 9850 Battery Replacement: stap 2, afbeelding 1 van 2 BlackBerry Torch 9850 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the plastic cover that would normally be on the back of the phone.
    • Press down on the release button, which is located on the bottom of the back side of the phone.
    • Lift up on the plastic covering and remove.
  3. BlackBerry Torch 9850 Battery Replacement: stap 3, afbeelding 1 van 3 BlackBerry Torch 9850 Battery Replacement: stap 3, afbeelding 2 van 3 BlackBerry Torch 9850 Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery.
    • Once the plastic covering is removed, you can remove the battery.
    • Use your fingers or a plastic spudger to pop the bottom of the battery out of its place by pushing and lifting.
    • Once the bottom of the battery has ejected, you can easily remove the whole battery from the phone with your hands.
  4. BlackBerry Torch 9850 Battery Replacement: stap 4, afbeelding 1 van 2 BlackBerry Torch 9850 Battery Replacement: stap 4, afbeelding 2 van 2
    • Inserting a new battery.
    • Align the plus and minus signs at the top of the battery compartment with the plus and minus signs at the top of the battery.
    • Push battery into place.
    • Replace the plastic cover by snapping into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rachel Staigerwald
712 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 564
