Ga door naar hoofdinhoud
BlackBerry Storm 9530 Logic/Motherboard Replacement
Wat je nodig hebt
  1. BlackBerry Storm 9530 Logic/Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 2, afbeelding 1 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 2, afbeelding 2 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the two hex screws as shown by the SIM card slot.
  4. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 4, afbeelding 1 van 2 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 5, afbeelding 1 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 5, afbeelding 2 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 6, afbeelding 1 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 6, afbeelding 2 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 7, afbeelding 1 van 1
    • You now have 3 pieces. The rear, mid , & front housing.
  8. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 8, afbeelding 1 van 2 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 8, afbeelding 2 van 2
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 9, afbeelding 1 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 9, afbeelding 2 van 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: stap 9, afbeelding 3 van 3
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
Conclusie
6 andere personen hebben deze handleiding voltooid.
Josh Forester
2.485 Reputatie
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 9,531
