Ga door naar hoofdinhoud
BlackBerry PlayBook Speaker Replacement
Wat je nodig hebt
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: stap 1, afbeelding 1 van 2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: stap 1, afbeelding 2 van 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: stap 2, afbeelding 1 van 1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: stap 3, afbeelding 1 van 2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: stap 3, afbeelding 2 van 2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: stap 4, afbeelding 1 van 2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: stap 4, afbeelding 2 van 2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: stap 5, afbeelding 1 van 1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: stap 6, afbeelding 1 van 2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: stap 6, afbeelding 2 van 2
    • Lift the right speaker bar to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan
661 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-27, Maness Fall 2014 Lid van Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 971
