Ga door naar hoofdinhoud
Inleiding
Many components of a tablet cannot be safely replaced individually, such as the CPU. Instead, you will likely want to replace the motherboard as a single unit.
  1. Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel. There are clips that need to be released on all four sides of the device.
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. Remove the battery connector using either your fingers or a pair of tweezers. Remove the battery connector using either your fingers or a pair of tweezers.
    • Remove the battery connector using either your fingers or a pair of tweezers.
  3. Unscrew two 1.17x2.9mm Phillips screws from the white connector port. Lift the battery connector away from the motherboard using a spudger.
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  4. Remove the flat-top connector coming from across the camera assembly with a spudger. Remove the flat-top connector coming from across the camera assembly with a spudger.
  5. With the spudger, remove the flat-top connector coming from underneath the motherboard. With the spudger, remove the flat-top connector coming from underneath the motherboard.
  6. Remove the clipped ZIF data connector coming from underneath the motherboard. Lift up the black plastic clip with a spudger. Pull the connector out gently using tweezers.
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  7. Remove the following five screws from the motherboard.
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  8. Lift all four antenna connectors from the motherboard again using the spudger.
  9. Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed. Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Nathan
640 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-27, Maness Fall 2014 Lid van Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Leden
12 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 2,925
