Ga door naar hoofdinhoud
BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball
Wat je nodig hebt
  1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: stap 1, afbeelding 1 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: stap 1, afbeelding 2 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: stap 1, afbeelding 3 van 3
    • Remove four screws total on the back of the phone casing near edge of battery area.
    • Two screws that are closer to the top of the phone are protected by plastic stoppers. Remove them then remove the screws.
    • There are two more screws on either side of where the battery was located. remove them as well.
  2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 2, afbeelding 1 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 2, afbeelding 2 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 2, afbeelding 3 van 3
    • Remove the bottom plastic piece.
    • This may require prying from a few different directions. The plastic blue prying tool featured here may be required.
  3. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 3, afbeelding 1 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 3, afbeelding 2 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 3, afbeelding 3 van 3
    • Once the keypad is removed, the buttons on the sides of the phone will fall out.
    • You will need to loosen the board from the right side opposite the charging ports.
    • Pull gently towards the right side so the ports clear the plastic casing.
    • Gently flip the board over to the left.
  4. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 4, afbeelding 1 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 4, afbeelding 2 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 4, afbeelding 3 van 3
    • On the back of the circuit board you will find a small rectangular blue piece with a black 'L' shape in the middle.
    • Gently detach this from the back of the main board.
    • Now you may fully remove the main board.
  5. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 5, afbeelding 1 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 5, afbeelding 2 van 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: stap 5, afbeelding 3 van 3
    • What is left inside the phone is the roller ball.
    • Gently use the plastic blue tool to detach it from the frame.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley
318 Reputatie
3 handleidingen geschreven
SUNY Cortland, Team 1-5, Getto Spring 2013 Lid van SUNY Cortland, Team 1-5, Getto Spring 2013
SUNYCORT-GETTO-S13S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 16
Altijd: 805
