Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
Remove the battery located directly below back panel.
Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
Gently remove the keyboard from front casing. It should snap out of place.
Één andere persoon heeft deze handleiding voltooid.
