Ga door naar hoofdinhoud
BlackBerry Pearl 8100 Disassembly
Wat je nodig hebt
  1. BlackBerry Pearl 8100 Disassembly, Rear Cover: stap 1, afbeelding 1 van 1
    • Push the button indicated by the yellow marker to remove the rear cover.
    • Remove the battery (not pictured).
  2. BlackBerry Pearl 8100 Disassembly, Screws underneath the rear cover: stap 2, afbeelding 1 van 1
    • Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
  3. BlackBerry Pearl 8100 Disassembly, Bottom Cover: stap 3, afbeelding 1 van 2 BlackBerry Pearl 8100 Disassembly, Bottom Cover: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
  4. BlackBerry Pearl 8100 Disassembly, Side Cover: stap 4, afbeelding 1 van 2 BlackBerry Pearl 8100 Disassembly, Side Cover: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to remove the side covers.
    • The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
  5. BlackBerry Pearl 8100 Disassembly, More screws: stap 5, afbeelding 1 van 1
    • With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
    • Use the T6 Torx screwdriver to remove the screws.
  6. BlackBerry Pearl 8100 Disassembly, Frame: stap 6, afbeelding 1 van 2 BlackBerry Pearl 8100 Disassembly, Frame: stap 6, afbeelding 2 van 2
    • With the screws removed, the frame can be detached.
  7. BlackBerry Pearl 8100 Disassembly, Logic Board: stap 7, afbeelding 1 van 2 BlackBerry Pearl 8100 Disassembly, Logic Board: stap 7, afbeelding 2 van 2
    • Use the plastic opening tool to separate the motherboard from the front cover.
    • While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
  8. BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: stap 8, afbeelding 1 van 2 BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: stap 8, afbeelding 2 van 2
    • Separate the keypad (first picture) and trackball (second picture) from the front cover.
    • Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
    • Keep the trackball intact. The trackball has extremely small magnetic bolts underneath that are difficult to reassemble.
  9. BlackBerry Pearl 8100 Disassembly, Complete: stap 9, afbeelding 1 van 1
    • These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin
150 Reputatie
2 handleidingen geschreven
Aristotle Lid van Aristotle
Community
5 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 676
