Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Carefully remove the top plastic cover. It is held in place by adhesive.
Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
Remove the two Philipps #0 screws securing the battery connector and unplug the later.
Remove the 6 Philipps #0 screws securing the lower cover and remove it.
Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
Remove the three Philipps #0 screws securing the upper cover and remove it.
Unplug the remaining ribbon cables
Remove the last three Philipps #0 screws securing the Motherbard.
Now you should be able to replace most components.
14 andere personen hebben deze handleiding voltooid.
