Wat je nodig hebt
The start of our disassembly. The BlackBerry KEYone logo screen.
Apply heat to the top of the phone to remove the microphone plastic cover. There is a fair amount of adhesive holding this cover down.
Use an iSesamo or other preferred pry tool to remove the plastic cover from the BlackBerry.
Remove the two Phillips screws. They may be hiding under some adhesive.
The plastic top of the phone will slide off after removing the two screws.
With the top plastic cover off it is pretty easy to use your preferred plastic pry tool and remove the battery cover.
Once the back cover is off remove the 7 Phillips Screws at the bottom of the phone that are covering the loudspeaker and the part of the motheboard where the USB type-C charging port is located.
Removing the loud speaker cover will allow you to remove the other two Phillips screws for the metal bracket that covers up a couple flex connectors.
Disconnect the two Phillips screws connecting the battery flex connector to the motherboard. Now you can remove the battery. There is ALOT of adhesive holding the battery in place. I recommend applying heat and using a plastic tool to slowly work the battery out. The volume and power flex runs under the battery. Be cautious near the top left.
With the battery out disconnect the three flex cables and remove the remaining two Phillips screws from this area of the motherboard.
There are three Phillips screws holding down a black plastic bracket that was previously partially covered by the silver bracket removed earlier. Two of the screws are visible without removing the silver top bracket but the third middle screws requires the top bracket be removed first.
With all screws and brackets removed and all flex cables disconnected you can now remove the motherboard. I recommend starting at the top (Rear facing camera side) and removing the board top down because the charging port sits in the frame of the phone and will come out more easily last.
All done the motherboard is out. Revealing the vibrate motor and headphone jack.
22 andere personen hebben deze handleiding voltooid.
20 opmerkingen
what about the screen on the front :)
Why the manufacturer always put so much adhesive on the battery??? To make it hard for people to install new ones?
I don't think so. To prevent any form of movement.
