Ga door naar hoofdinhoud
BlackBerry Curve 8900 Motherboard Replacement
Wat je nodig hebt
  1. BlackBerry Curve 8900 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Motherboard Replacement: stap 2, afbeelding 1 van 2 BlackBerry Curve 8900 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Motherboard Replacement: stap 6, afbeelding 1 van 2 BlackBerry Curve 8900 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Motherboard Replacement: stap 7, afbeelding 1 van 2 BlackBerry Curve 8900 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Motherboard Replacement: stap 9, afbeelding 1 van 2 BlackBerry Curve 8900 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Motherboard Replacement: stap 10, afbeelding 1 van 2 BlackBerry Curve 8900 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Johnny Tran
473 Reputatie
4 handleidingen geschreven
Cuesta, Team 1-3, Zipperian Fall 2011 Lid van Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 61
Altijd: 4,156
