Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press and slide the battery cover from the back of the device with your fingers.
Remove the battery by pulling it out.
Gereedschap gebruikt in deze stap:iFixit Opening Tool$1.99-
Using the iFixit Opening Tool, remove the lower rear cover.
Gereedschap gebruikt in deze stap:T6 Torx Screwdriver$9.99-
Using a T6 Torx screwdriver, remove the six screws.
Using the iFixit Opening Tool or your fingers, remove the midframe of the phone.
Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
With your fingers, carefully remove the screen so as not to damage it.
With your fingers, carefully unhook the antenna cable in all three locations.
Gereedschap gebruikt in deze stap:Spudger$3.99-
Detach the ribbon cable on the front of the motherboard using the Spudger tool.
Detach the motherboard from both ribbon connections.
The ribbon connections are indicated by red circles on the photograph.
The ribbon connections are indicated by orange rectangles on the photograph.
Replace the entire motherboard to replace the microphone.
Één andere persoon heeft deze handleiding voltooid.
