Ga door naar hoofdinhoud
BlackBerry Curve 8900 Microphone Replacement
Wat je nodig hebt
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: stap 1, afbeelding 1 van 1
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
  2. BlackBerry Curve 8900 Microphone Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    iFixit Opening Tool
    $1.99
    • Using the iFixit Opening Tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Microphone Replacement: stap 3, afbeelding 1 van 1
    T6 Torx Screwdriver
    $9.99
  4. BlackBerry Curve 8900 Microphone Replacement: stap 4, afbeelding 1 van 1
    iFixit Opening Tool
    $1.99
  5. BlackBerry Curve 8900 Microphone Replacement: stap 5, afbeelding 1 van 2 BlackBerry Curve 8900 Microphone Replacement: stap 5, afbeelding 2 van 2
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
  6. BlackBerry Curve 8900 Microphone Replacement: stap 6, afbeelding 1 van 1
    • With your fingers, carefully remove the screen so as not to damage it.
  7. BlackBerry Curve 8900 Microphone Replacement: stap 7, afbeelding 1 van 2 BlackBerry Curve 8900 Microphone Replacement: stap 7, afbeelding 2 van 2
    • With your fingers, carefully unhook the antenna cable in all three locations.
  8. BlackBerry Curve 8900 Microphone Replacement: stap 8, afbeelding 1 van 1
    Spudger
    $3.99
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
  9. BlackBerry Curve 8900 Microphone Replacement: stap 9, afbeelding 1 van 1
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
  10. BlackBerry Curve 8900 Microphone Replacement: stap 10, afbeelding 1 van 2 BlackBerry Curve 8900 Microphone Replacement: stap 10, afbeelding 2 van 2
    • Replace the entire motherboard to replace the microphone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnny Tran
473 Reputatie
4 handleidingen geschreven
Cuesta, Team 1-3, Zipperian Fall 2011 Lid van Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 4,485
