Ga door naar hoofdinhoud
BlackBerry Curve 8900 Keypad Replacement
Wat je nodig hebt
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: stap 1, afbeelding 1 van 1
    • Remove the back cover and the battery from the device.
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: stap 2, afbeelding 1 van 1
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: stap 3, afbeelding 1 van 1
    • Remove all six T6 screws from the midframe.
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: stap 4, afbeelding 1 van 1
    • Separate the midframe from the rest of the device.
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: stap 5, afbeelding 1 van 1
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: stap 6, afbeelding 1 van 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: stap 6, afbeelding 2 van 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: stap 6, afbeelding 3 van 3
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Renae Bishop
68 Reputatie
4 handleidingen geschreven
Cuesta, Team 1-3, Zipperian Fall 2011 Lid van Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 6,983
