Wat je nodig hebt
Place the phone on a flat surface with the screen facing down.
Remove the plastic backplate by pulling up on the bottom of the cover.
Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
Flip the phone over so the keyboard faces up.
Insert a plastic spudger into the screen where speaker resides.
I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
Gently lift up plastic screen cover until screen cover separates from screen.
Continue until screen cover is completely removed.
To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
Note: When reassembling, the ribbon should be reattached before replacing the top screws.
Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
Flip over the motherboard.
There is another torx screw near the middle of the motherboard on the left side.
Using the T5 Torx Screwdriver, remove the screw and the metal casing.
Note: Distinguish this screw from the others for reassembly purposes.
Detach the clip holding the track pad in.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
No need to full disassemble the phone. Just remove the back and the battery and unscrew the T5 screw, presto 20 minutes saved.
