Ga door naar hoofdinhoud
BlackBerry Curve 8520 Motherboard Replacement
Wat je nodig hebt
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: stap 2, afbeelding 1 van 2 BlackBerry Curve 8520 Motherboard Replacement, Battery: stap 2, afbeelding 2 van 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: stap 3, afbeelding 1 van 2 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: stap 3, afbeelding 2 van 2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: stap 4, afbeelding 1 van 2 BlackBerry Curve 8520 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: stap 5, afbeelding 1 van 3 BlackBerry Curve 8520 Motherboard Replacement: stap 5, afbeelding 2 van 3 BlackBerry Curve 8520 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: stap 6, afbeelding 1 van 3 BlackBerry Curve 8520 Motherboard Replacement: stap 6, afbeelding 2 van 3 BlackBerry Curve 8520 Motherboard Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: stap 8, afbeelding 1 van 2 BlackBerry Curve 8520 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
Conclusie
32 andere personen hebben deze handleiding voltooid.
Matt
1.722 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-62, Walters Spring 2011 Lid van Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Leden
Één opmerking
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 36,829
