Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace the screen of the BlackBerry Curve 8520.
Wat je nodig hebt
Insert a plastic opening tool into the small notch on the rear cover of the phone.
Pry the rear cover up from the phone.
Locate the slit between the top of the battery and the casing.
Gently apply pressure on the top of the battery to trigger the spring release.
Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
Remove the four T6 Torx screws from the corners of the keyboard.
10 andere personen hebben deze handleiding voltooid.
