Ga door naar hoofdinhoud
BlackBerry Curve 8310 LCD Screen Replacement
Wat je nodig hebt
  1. BlackBerry Curve 8310 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 LCD Screen Replacement, Lens: stap 3, afbeelding 1 van 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 LCD Screen Replacement: stap 6, afbeelding 1 van 3 BlackBerry Curve 8310 LCD Screen Replacement: stap 6, afbeelding 2 van 3 BlackBerry Curve 8310 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. BlackBerry Curve 8310 LCD Screen Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Remove the keyboard.
  8. BlackBerry Curve 8310 LCD Screen Replacement, Screen Housing: stap 8, afbeelding 1 van 1
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. BlackBerry Curve 8310 LCD Screen Replacement: stap 9, afbeelding 1 van 2 BlackBerry Curve 8310 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Now remove the left and right side panels.
  10. BlackBerry Curve 8310 LCD Screen Replacement: stap 10, afbeelding 1 van 3 BlackBerry Curve 8310 LCD Screen Replacement: stap 10, afbeelding 2 van 3 BlackBerry Curve 8310 LCD Screen Replacement: stap 10, afbeelding 3 van 3
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. BlackBerry Curve 8310 LCD Screen Replacement, LCD Screen: stap 11, afbeelding 1 van 1
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. BlackBerry Curve 8310 LCD Screen Replacement: stap 12, afbeelding 1 van 1
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Mandy Chan
91 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-32, Amido Winter 2012 Lid van Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,753
