Ga door naar hoofdinhoud
BlackBerry 8820 Motherboard Replacement
Wat je nodig hebt
  1. BlackBerry 8820 Motherboard Replacement, Disassembling BlackBerry 8820 Outer Casing: stap 1, afbeelding 1 van 1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Motherboard Replacement: stap 2, afbeelding 1 van 2 BlackBerry 8820 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Motherboard Replacement: stap 3, afbeelding 1 van 2 BlackBerry 8820 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 BlackBerry 8820 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the bottom casing clip, it will easily unsnap when pulled
  7. BlackBerry 8820 Motherboard Replacement: stap 7, afbeelding 1 van 2 BlackBerry 8820 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
  8. BlackBerry 8820 Motherboard Replacement: stap 8, afbeelding 1 van 2 BlackBerry 8820 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, unattach this cable by levering under the connector
    • When removing the ribbon cable handle with care; it is prone to breaking
  9. BlackBerry 8820 Motherboard Replacement: stap 9, afbeelding 1 van 2 BlackBerry 8820 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • WARNING: Be sure to have disconnected the SATA cable strap prior to attempting this.
    • Using the prying tool, lever up the old screen as shown.
  10. BlackBerry 8820 Motherboard Replacement: stap 10, afbeelding 1 van 3 BlackBerry 8820 Motherboard Replacement: stap 10, afbeelding 2 van 3 BlackBerry 8820 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
    • After you remove the old motherboard, you can then replace it with a new one.
Conclusie
3 andere personen hebben deze handleiding voltooid.
ryan
44 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-64, Johann Spring 2013 Lid van Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 910
