Ga door naar hoofdinhoud
BlackBerry 8820 LCD Screen Replacement
Wat je nodig hebt
  1. BlackBerry 8820 LCD Screen Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 LCD Screen Replacement: stap 2, afbeelding 1 van 2 BlackBerry 8820 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: stap 3, afbeelding 1 van 2 BlackBerry 8820 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 1
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: stap 7, afbeelding 1 van 2 BlackBerry 8820 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, disconnect the SATA cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: stap 8, afbeelding 1 van 2 BlackBerry 8820 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Using a spudger, pry up the old screen as shown.
    • Be sure that the SATA cable is disconnected prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: stap 9, afbeelding 1 van 2 BlackBerry 8820 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Insert the new LCD screen.
    • Attach the cable to the connector located at the top of the phone.
Conclusie
ryan
44 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-64, Johann Spring 2013 Lid van Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 782
