Ga door naar hoofdinhoud
BlackBerry 8703e Battery Replacement
Wat je nodig hebt
  1. BlackBerry 8703e Battery Replacement, Battery: stap 1, afbeelding 1 van 2 BlackBerry 8703e Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: stap 2, afbeelding 1 van 1
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
Conclusie
Johnathon Gorski
22 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-3, Forte Winter 2010 Lid van Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 3,385
