Ga door naar hoofdinhoud
BlackBerry 7510 Logic Board Replacement
Wat je nodig hebt
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: stap 1, afbeelding 1 van 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: stap 5, afbeelding 1 van 2 BlackBerry 7510 Logic Board Replacement: stap 5, afbeelding 2 van 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: stap 6, afbeelding 1 van 1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: stap 8, afbeelding 1 van 1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: stap 9, afbeelding 1 van 1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: stap 10, afbeelding 1 van 2 BlackBerry 7510 Logic Board Replacement: stap 10, afbeelding 2 van 2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: stap 11, afbeelding 1 van 2 BlackBerry 7510 Logic Board Replacement: stap 11, afbeelding 2 van 2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
Conclusie
Neil Johnson
12 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-44, Regan Winter 2010 Lid van Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,839
