Ga door naar hoofdinhoud
BlackBerry 7510 LCD Screen Replacement
Wat je nodig hebt
  1. BlackBerry 7510 LCD Screen Replacement, Back Face of Phone: stap 1, afbeelding 1 van 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Lift off the back cover.
  4. BlackBerry 7510 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 LCD Screen Replacement: stap 5, afbeelding 1 van 2 BlackBerry 7510 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 1
    • Unscrew the screw holding the back plate.
  7. BlackBerry 7510 LCD Screen Replacement: stap 7, afbeelding 1 van 2 BlackBerry 7510 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
    • Lift off front cover from metal plate.
  8. BlackBerry 7510 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Pry off the LCD screen with spudger at the two clips.
  9. BlackBerry 7510 LCD Screen Replacement: stap 9, afbeelding 1 van 2 BlackBerry 7510 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the LCD screen and replace it with a new one.
    • Careful not to rip the LCD ribbon.
Conclusie
Neil Johnson
12 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-44, Regan Winter 2010 Lid van Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,677
