Ga door naar hoofdinhoud
BlackBerry 7290 Side Button Replacement
Wat je nodig hebt
  1. BlackBerry 7290 Side Button Replacement, Battery: stap 1, afbeelding 1 van 3 BlackBerry 7290 Side Button Replacement, Battery: stap 1, afbeelding 2 van 3 BlackBerry 7290 Side Button Replacement, Battery: stap 1, afbeelding 3 van 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 Side Button Replacement: stap 2, afbeelding 1 van 3 BlackBerry 7290 Side Button Replacement: stap 2, afbeelding 2 van 3 BlackBerry 7290 Side Button Replacement: stap 2, afbeelding 3 van 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 Side Button Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 Side Button Replacement: stap 4, afbeelding 1 van 2 BlackBerry 7290 Side Button Replacement: stap 4, afbeelding 2 van 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 Side Button Replacement, Side Button: stap 5, afbeelding 1 van 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 Side Button Replacement: stap 6, afbeelding 1 van 2 BlackBerry 7290 Side Button Replacement: stap 6, afbeelding 2 van 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 Side Button Replacement: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 Side Button Replacement: stap 8, afbeelding 1 van 3 BlackBerry 7290 Side Button Replacement: stap 8, afbeelding 2 van 3 BlackBerry 7290 Side Button Replacement: stap 8, afbeelding 3 van 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 Side Button Replacement: stap 9, afbeelding 1 van 2 BlackBerry 7290 Side Button Replacement: stap 9, afbeelding 2 van 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
Conclusie
Jschutt
79 Reputatie
1 Handleiding geschreven
Cal Poly, Team 19-6, Maness Fall 2009 Lid van Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 3,910
