Ga door naar hoofdinhoud
BlackBerry 7280 Front Case Replacement
Wat je nodig hebt
  1. BlackBerry 7280 Front Case Replacement, Battery: stap 1, afbeelding 1 van 3 BlackBerry 7280 Front Case Replacement, Battery: stap 1, afbeelding 2 van 3 BlackBerry 7280 Front Case Replacement, Battery: stap 1, afbeelding 3 van 3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Front Case Replacement: stap 2, afbeelding 1 van 2 BlackBerry 7280 Front Case Replacement: stap 2, afbeelding 2 van 2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Front Case Replacement, SIM Card: stap 3, afbeelding 1 van 3 BlackBerry 7280 Front Case Replacement, SIM Card: stap 3, afbeelding 2 van 3 BlackBerry 7280 Front Case Replacement, SIM Card: stap 3, afbeelding 3 van 3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Front Case Replacement, Back Case: stap 4, afbeelding 1 van 2 BlackBerry 7280 Front Case Replacement, Back Case: stap 4, afbeelding 2 van 2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Front Case Replacement: stap 5, afbeelding 1 van 2 BlackBerry 7280 Front Case Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Front Case Replacement, Front Case: stap 6, afbeelding 1 van 2 BlackBerry 7280 Front Case Replacement, Front Case: stap 6, afbeelding 2 van 2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Front Case Replacement: stap 7, afbeelding 1 van 2 BlackBerry 7280 Front Case Replacement: stap 7, afbeelding 2 van 2
    • Remove the front plastic case from the metal bracket.
Conclusie
Andrew Catlin
16 Reputatie
3 handleidingen geschreven
Clemson, Team 12-2, Benson Spring 2013 Lid van Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 336
