Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The outer shell of the BlackBerry 7280 has two main parts, the back case and the front case. The back case is the first part that has to be removed, and allows access to more internal parts of the device.
Onderdelen
Geen onderdelen opgegeven.
  1. With your thumb press down on the locking- button on the back of the BlackBerry 7280. Slide the battery cover off the device. Slide the battery cover off the device.
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. Remove the lithium-ion battery from the back of the device using your index finger. Remove the lithium-ion battery from the back of the device using your index finger.
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. Hold the device with both hands. Lift the SIM card holder using your thumb and index finger. Remove the SIM card from the device.
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside. The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. Use the plastic opening tool to pry the back case away from the front case. Use the plastic opening tool to pry the back case away from the front case.
    • Use the plastic opening tool to pry the back case away from the front case.
Conclusie
Sarah Waddill
10 Reputatie
5 handleidingen geschreven
Clemson, Team 12-2, Benson Spring 2013 Lid van Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 266
