Ga door naar hoofdinhoud
BlackBerry 7130e battery replacement
Wat je nodig hebt
  1. BlackBerry 7130e battery replacement, battery: stap 1, afbeelding 1 van 1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e battery replacement: stap 2, afbeelding 1 van 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e battery replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Conclusie
Sean Tiernan
5 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-16, Maness Winter 2010 Lid van Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,952
