Ga door naar hoofdinhoud
BlackBerry 7130e Keypad Replacement
Wat je nodig hebt
  1. BlackBerry 7130e Keypad Replacement, battery: stap 1, afbeelding 1 van 1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e Keypad Replacement: stap 2, afbeelding 1 van 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e Keypad Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
  4. BlackBerry 7130e Keypad Replacement, BlackBerry 7130e Disassembly: stap 4, afbeelding 1 van 1
    • Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
  5. BlackBerry 7130e Keypad Replacement: stap 5, afbeelding 1 van 1
    • Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
  6. BlackBerry 7130e Keypad Replacement: stap 6, afbeelding 1 van 1
    • Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
    • As you detach the speaker phone cover you will notice a sticky glue sealing the rubber gasket from the cover to the speaker mesh. This is normal and will correctly reset the first few times the pieces are separated.
  7. BlackBerry 7130e Keypad Replacement: stap 7, afbeelding 1 van 1
    • Remove top two screws with T6 Torx screw driver, from the back of phone.
  8. BlackBerry 7130e Keypad Replacement: stap 8, afbeelding 1 van 1
    • Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
  9. BlackBerry 7130e Keypad Replacement: stap 9, afbeelding 1 van 2 BlackBerry 7130e Keypad Replacement: stap 9, afbeelding 2 van 2
    • You should now be able to easily separate the phone into two pieces.
    • The battery prong may fall out when the separation occurs, just don't loose it!
  10. BlackBerry 7130e Keypad Replacement, Replace Keypad: stap 10, afbeelding 1 van 1
    • Once the phone comes apart into two pieces,the key buttons are on the inside of the front panel of the phone.
    • The buttons will fall out of the phone when you turn it over.
  11. BlackBerry 7130e Keypad Replacement: stap 11, afbeelding 1 van 1
    • Simply insert a new set of buttons and reassemble the phone.
    • Continue on with the guide if you are replacing the key pad circuit board that is beneath the key pad.
  12. BlackBerry 7130e Keypad Replacement: stap 12, afbeelding 1 van 1
    • Turn the part of phone with circuit board for the keypad still attached upside down.
    • Remove the four screws outlining the keypad with the T6 Torx screw driver.
  13. BlackBerry 7130e Keypad Replacement: stap 13, afbeelding 1 van 1
    • Wedge the plastic opening tool between the circuit board and the black hinge of the keypad.
    • Pry the black latch up and the keypad will come loose.
  14. BlackBerry 7130e Keypad Replacement: stap 14, afbeelding 1 van 1
    • Carefully detach the keypad board from the phone.
    • There is no need to unlatch the opposite side, it will come loose freely. Just be careful to snap back on both sides when you put on the new keyboard.
    • Watch out the plastic cap on the bottom of the phone fall loose at this point. Just don't loose it or forget to re-assemble.
Conclusie
Sean Tiernan
5 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-16, Maness Winter 2010 Lid van Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 49
Altijd: 2,314
