Ga door naar hoofdinhoud
BlackBerry 7100g Screen Replacement
Wat je nodig hebt
  1. BlackBerry 7100g Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Screen Replacement: stap 2, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement: stap 2, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement: stap 2, afbeelding 3 van 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Screen Replacement, Housing: stap 4, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement, Housing: stap 4, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement, Housing: stap 4, afbeelding 3 van 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Screen Replacement: stap 5, afbeelding 1 van 2 BlackBerry 7100g Screen Replacement: stap 5, afbeelding 2 van 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Screen Replacement: stap 6, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement: stap 6, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement: stap 6, afbeelding 3 van 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Screen Replacement: stap 7, afbeelding 1 van 1
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Screen Replacement, Keypad: stap 8, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement, Keypad: stap 8, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement, Keypad: stap 8, afbeelding 3 van 3
    • Turn the "guts" over so the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
    • Separate the battery housing from the motherboard.
  9. BlackBerry 7100g Screen Replacement: stap 9, afbeelding 1 van 1
    • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
  10. BlackBerry 7100g Screen Replacement, Screen: stap 10, afbeelding 1 van 2 BlackBerry 7100g Screen Replacement, Screen: stap 10, afbeelding 2 van 2
    • Locate the ribbon connector below the bottom of the screen.
    • Use a spudger to flip up the connector.
  11. BlackBerry 7100g Screen Replacement: stap 11, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement: stap 11, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement: stap 11, afbeelding 3 van 3
    • Locate the four (4) white tabs that attach the screen to the motherboard.
    • Carefully detach the tabs from the motherboard.
    • The screen can now be removed from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adriel Salinas
42 Reputatie
2 handleidingen geschreven
Cal Poly, Team 25-87, Amido Spring 2010 Lid van Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Leden
16 handleidingen geschreven
Één opmerking
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,838
