Ga door naar hoofdinhoud
Black and Decker WP900 Power Cord Replacement
Wat je nodig hebt
  1. Black and Decker WP900 Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Cord Replacement: stap 2, afbeelding 1 van 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Cord Replacement: stap 3, afbeelding 1 van 3 Black and Decker WP900 Power Cord Replacement: stap 3, afbeelding 2 van 3 Black and Decker WP900 Power Cord Replacement: stap 3, afbeelding 3 van 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Cord Replacement: stap 4, afbeelding 1 van 1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Cord Replacement: stap 5, afbeelding 1 van 2 Black and Decker WP900 Power Cord Replacement: stap 5, afbeelding 2 van 2
    • Gently pull the power cord out from the control module.
    • This is the part to be replaced. Remember to insert the black wire into the top port when installing the new cord.
Conclusie
Cameron
231 Reputatie
2 handleidingen geschreven
IUPUI, Team 8-8, Wilson Spring 2016 Lid van IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 278
